[Big Muff] Volume pot does nothing...
Started by funkysam, March 07, 2005, 10:27:13 AM
funkysam
Hi all,
I've finished my BM e few days ago.
I get a distorted sound on the output, but the volume pot does nothing.
I measured it with a DMM and it seems to work correctly.
Any ideas?
I'll post Q voltages if necessary ;-)
Sam.
Marcos - Munky
I believe that you wired your pot wrong.
funkysam
I'll double-check it but I don't think so...
there are not a lot of ways to wire it ;-)
Alex C
Does the rest of the circuit work?
From what you said, it sounds like it does, and the volume pot isn't varying the volume level. Is this the case - the "distortion sound" is the kind that you want (the BMP sound)?
If this is the case, I'd re-check the volume pot wiring.
funkysam
Well,
here are my Q voltages:
Q1
E:0.02
B:0.61
C:3.79
Q2
E:0.02
B:0.61
C:3.77
Q3
E:0.04
B:0.65
C:1.12
Q4
E:0.94
B:1.53
C:3.48
Battery: 7.8V
My pot wiring is good.
Are those voltages correct?
