Understanding relationships of grounding, polarity & tra
Started by powerplayj, March 07, 2005, 11:15:52 PM
powerplayj
I've got parts for a PNP Rangemaster (neg grd) and PNP Boutique Fuzz on the plate and plan to do the RM first for the sake of simplicity.  I'm still a little bit unsure between the relationship of Transistor type, polarity and ground (+/-).
How should a circuit be configured in order to accomodate a Boss adapter?  I assume the ground should be negative but what about the supply voltage?  I have read varying opinions about changing the polarity of Ge circuits.  Do either of these circuits pose oscillation problems?  Also, I'm not as keen on batteries because I sometimes forget to unplug the pedal jacks.
Thanks,
Jason
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
