spdt switch - where to get on/off/on?
Started by wampcat1, March 09, 2005, 02:09:03 PM
wampcat1
Anyone know where I can get a spdt/dpdt stomp switch that is on/off/on?
Didn't see it at the usual places...
Thanks,
Brian
NOt sure what you mean...
 I've used spdt's using only two fo the wires: for each switching it goes, one side is connect, one side disconnect
 One center and one outside lug of a standard stompsw. ...don't know if you can get SpDt stomperz...
 I use the 3 lug sw out of the old VOX wah for this purpose.
Quote from: petemooreNOt sure what you mean...
 I use the 3 lug sw out of the old VOX wah for this purpose in a two fuzz box, because the mods are one side to ground, I connect that to the 'common' then it's an emitter bypass cap or LF filter cap to ground from either of the two switch outputs...so it does something different to each of the two effects...*Where does THIS Wire Go oH :idea: " !  !!
AL
Try here. They've usually got a decent selection. 1N34A diodes for cheap and CA3080E's - get 'em while they're hot !!
http://www.web-tronics.com/
AL
