Wanted-Rocker switch-please read on>>>>
Started by Gstring, March 10, 2005, 08:02:12 PM
Gstring
The unit I am looking for is a on-off-on unit with two small metal ears-threaded holes on each ear for mounting-here is the stumbling block-the one I require also has a piece of approx 1/4" roundstock as the actuation handle.Can anyone help?
onboard
What's it for? Does it have to have the bat, or can you use a standard rocker? Did you try the usual Mouser, Digikey search?
That's a good one  :?
-Ryan
"Bound to cover just a little more ground..."
Gstring
Yes I looked at all avenues-the switch portion must reside below the mtg, area and the "bat" is actually the 1/4" aluminum rod which protrudes through  a slotted hole-The switch is used on a Multivox effect
Dan N
I can't find my main switch junkbox, but did find this guy laying around:
http://users.rio.com/senorris/junk/sw1s.jpg
At all similar to what you are looking for?
