MORE VEROBOARD/STRIPBOARD FUN !!!!
Started by Dragonfly, March 14, 2005, 02:33:26 PM
Dragonfly
...for your enjoyment, i present the "Knight Fuzz" ...i havent built this yet, but from the looks of it, this fuzz should sound pretty good ! no transistors or diodes were specified on the schemo, but most med/high gain NPNs should work for trannies, and you might want to socket the diodes to try out different types.
anyway, heres a layout for you!
enjoy !
Andy
Dragonfly FX
j0shua
cool Draw , and easy to build :D , i try this one hehe im not fuzz fan but i can play whit the diodes ;)
Agreed !! Looks like a fine set up for Fuzz !!!
 EZ  Build !!!
Mihkel
Oops! I see a jumper missing on the DPDT...
RCZ53
Just wondering what the origin of this Fuzz is? There used to be Knight kits I think back in the 70's? Just curious. Thanks....regards Roger
Dragonfly
Quote from: MihkelOops! I see a jumper missing on the DPDT...
yep...thats what happens when you do a layout on lunch break... :)
its been corrected :) ...
thanks,
 andy
James P
Hi Dragonfly
great work, do you ever sleep? I think you've got an NPN and PNP transistor instead of two NPN's on the layout. Sorry to be picky!!
I'm also looking to put a F***tone 69 pedal together. Can you help with a layout i'm making please?
Regards
James P
If i'm not back in 5 minutes, just wait longer...
Torchy
James - I think the '69 pedal is very similar to the '70 pedal. I dont have the schematic (you got a link ?) but the vero layout for the '70 may give you a goood starting point ...
hilbi
hilbi
Built so far: PNP FuzzFace, MXR Dynacomp, EA Tremolo, AMZ Mosfet Boost, AMZ Super Buffer, Blue Magic, Peppermill, RM Axis Face, Sparkle Boost, BSIABII, ROG Ruby, AMZ Mini Booster, MXR Phase 45 Univibe, Tremulus Lune, Dallas Rangemaster, Ross Comp
James P
Thanks guys
Torchy - is there a schem anywhere with off board parts wiring, or is it a standard 3PDT type?
Regards
James
P.S. Did you get my PM Torchy?
Quote from: James PThanks guys
Regards
James
>>>That ^ schematic shows the offboard wiring, ITC using a DPDT bypass Sw.
James P
Quote>>>That ^ schematic shows the offboard wiring, ITC using a DPDT bypass Sw.
Beg your puddin Pete!
Thanks for helping me see past the end of my nose!!! :D
James P
Dragonfly
Quote from: James PHi Dragonfly
Regards
James P
if you can pm a schematic to me, i'l see what i can do !
andy
