DI BOX with FET (J201)??
Started by mathflan, March 23, 2005, 07:58:18 AM
mathflan
Hi
I'd like to know if there are schematics for a direct box injection wich use FET transistor like J201.
http://sounddiy.free.fr
mathflan
Because I like the sound of the J201 and that there produce less noise that an opamp like TL071.
Hookup a Jfet and see whappens...unless you want something else in there. too..?
octafish
Checkout the simple sim
http://www.diystompboxes.com/analogalchemy/pedals/simplesim.html
not jfets but I built one for a mate and he loves it.
Shoot straight you bastards. Don't make a mess of it. -Last words of Breaker Morant
StephenGiles
Kleber AG
Hey Stephen have you used a transformer as per the schem? Is it possible and worth to sub for an active electronic balanced XLR output???
It's hard for me to find those transformers here....
Regards
Kleber AG
Gilles C
I used Don TillMan Active Preamp
http://www.till.com/articles/PreampCable/index.html
and I was thinking of using these 3 circuits as inspiration to make it a balanced output circuit.
http://www.uwm.edu/People/msw/ActivePlug/BootStrap.html
My suggestion: use the first FET as input buffer and use it for one side of the balanced output. Feed the output of that same first FET to an output buffer as the above circuits. Just make sure that the second output is out of phase with the other output. From how Jensen uses it, it should be how of phase.
Gilles
