Oscillation problem solved
Started by dosmun, March 25, 2005, 07:48:35 PM
dosmun
I built a TS with Landgraff mods using Torchys vero layout.  It had oscillation problems that I had a hard time tracking down.  I finally found the problem which was the input wire between the board and the input jack.  I ended up using a shielded wire and connecting the shield to ground.  All is well again in DIY land. :D
