Andreton's Phaser on modified GGG layout.
Started by jrc4558, March 26, 2005, 10:36:51 PM
jrc4558
Hi everybody! I would like to ask you all and Master JD primarily, whether there is a component overlay picture for the modified layout (the 8pin opamps one).
I seem to be at loss with some resistors placements... :(
R 19,32,31,8,37,38... Also C11&10...
Any help would be appreciated. :)
Thanks in advance.
gorohon
There's an extra jumper in GGG's PCB too.  Those resistors were hard to find their homes on mine but they're just slighty turned/ moved a bit from the spot where Anderton has them, at least that's what I recall from my build.  Those caps' locations are hard to figure out too.   Those are the ones that go between the two 5332's, right?  One cap has a tight fit, like it should be the size of a tantalum cap, then the other one stretches out long, parallel with the IC's, and would be better suited as an axial type cap.  I had to follow the schematic along with figuring where the revised GGG traces were going to get these locations figured out.  It made my eyes hurt :(
"Come on in...I've got caaandy!" H.S.
