True Bypass Help
Started by Erocku, March 27, 2005, 02:47:27 PM
Erocku
I was going to wire my wah for true bypass -w- LED. I have a 3PDT switch. I foudn this site that shows how to do the mod with a DPDT without LED. I was wondering if one of ya'll can help me out with how to put it to 3PDT with  LED.
ESPguitar
Do you understand how a 3dpdt switch is functioning???
If you give me 10 minutes i will post a schemtaic for you...
RB
NaBo
check the wiring diagrams in the "Tech" section of GGG, //www.generalguitargadgets.com
ESPguitar
http://community.webshots.com/scripts/editPhotos.fcgi?action=showMyPhoto&albumID=301426109&photoID=306348237&security=LPGStp
Check that link, each rectangle is a solder point on the switch,
The solder points in the middle (they have a line drawn to the outer row)
is your basis point.
the swith controls wich of the outer rows of contacts to use.
Do you understand that?
RB
ESPguitar
Quote from: NaBocheck the wiring diagrams in the "Tech" section of GGG, //www.generalguitargadgets.com
It's always good to know exactly how things is working isn't it??
:wink:
RB
