Capacitor help, codes and adding values?
Started by Narcosynthesis, April 01, 2005, 12:05:54 PM
Narcosynthesis
hello, for a project i am making i need one 330pf and one 470pf (for other 330pf caps i have used 300pf instead, but i dont have any more of those)
how do you go about adding and dividing the values? i have 100, 1000 and 220pf values, so would i be able to add these together in some way to get close to the desired values? how does connecting them in series/parallel affect the overall value?
also, i have some spare caps from other attempted projects, problem being i dont know what values they are... can you work the values out from the codes on them? they are -
473 (which is a small blue cap)
475 (which is a yellow blobbish (tantalum?) cap)
anyone able to help?
David
nelson
This tool is useful for working out the capacitance of capacitors in series. you need javascript installed to use it.
http://www.csgnetwork.com/seriescapacicalc.html
This link will teach you how to read capacitor value codes.
http://xtronics.com/kits/ccode.htm
And just for good measure and future reference here is a capacitance converter for converting between the different values nF uF pF etc.
http://www.electronics2000.co.uk/calc/convcap.htm
Enjoy and good luck.
My project site
Winner of Mar 2009 FX-X
j0shua
Narcosynthesis
so that would make 473 a 47nf (47000pf) cap and 475 a 4.7uf (4700000pf) caps
for adding values, i think it works the opposite way from resisters, ie caps in parallell add values, and 1/ct = 1/c1 + 1/c2... for series capcitance
now for a way to work out if i can get the values i want from what i have...
David
