Vanishing point - clock still not clocking
Started by lightningfingers, April 02, 2005, 06:28:32 AM
lightningfingers
I've made a completely new board with the 4093 and I KNOW its wired correctly this time. Its a verysimple circuit, only 5 parts....could the LED i'm using to test it be loading the clock down?
U N D E F I N E D
The Tone God
Ok. Stop. Breath deeply. Now PANIC!!! j/k
Let break this down. Pull out the 4017. (You did put the ICs in sockets right ?!?) Disconnect the cap (stated as 0.01uF in the schematic) from pin 3 of the 4093. Now attach your LED to pin 3 with the flat side of the LED to a current limiting resistor, say 1K, that is in turn attached to ground.
Report back afterwards with results.
Andrew
lightningfingers
LED pulses at frequency determined by 100K pot  :lol: I wonder why then, it didnt work with a plain LED (no resistor)....
Well Thanks for that, now I just have to build the part with the 4017 (i started a completely new board as the last one didnt work...decided to make sure each part is fully working before moving on)
U N D E F I N E D
The Tone God
Good idea to start over and work bit by bit.
Using an LED with no current limiting resistor is a bad idea. The LED will pull too much current from the IC which is probably why it didn't work. :)
Good luck.
Andrew
