Stereo LFO
Started by walters, April 09, 2005, 08:21:39 PM
walters
1.) How to make a Stereo LFO
              a.) Output#1 with be the Positive Peak of the LFO
              b.) Output#2 with be the Negative Peak of the LFO
2.) so the Phase shift#1 is getting only the Positive Rectified LFO
    and the Phase Shift#2 is getting the Negative Peak of the LFO
Processaurus
Are you asking how to make an inverted copy of an LFO wave? Maybe explain a bit more what you're after and how it will be used.
toneman
just build a "regualr"  (tirangle?)  LFO, then,
run it thru an inverting opamp.
U might buffer both outputs so as not to load them down.
also, a dual output level control might B usefull.
stayLFO(ed)
tone
Walters, can you tell us how much electronics background you have before signing on here today?
Your questions indicate either a need for some basic electronics understanding or an unfamiliarity with English, or both. I do not mean those as insults, just observations.
I'm thinking we can do more for you by recommending electronics basics that typing in an electronics education out of order as you think up the questions.
Again, I am not intending to be insulting, just trying to help in a way that I think will be faster for you.
