Straight volume boost
Started by Ptownkid, April 11, 2005, 10:46:35 AM
Ptownkid
I want to build a volume boost box that'll take my amp from cleanish to normal.  What i mean is, I want one setting to act like you have the volume turned down on your guitar, and then when i press the switch, it allows the full volume to come thru.
Ask and you shall receive.
Actually, you already received. The "Multi-Vol" was published at GEO on June 13, 2000.
http://geofex.com/Article_Folders/multivol/multivol.htm
For the limited case of only two selections, you can use a single DPDT stomp switch instead of the 4053 and CMOS selector logic. Just replace the CD4053 section in two of the channels with the stompswitch sections.
Ptownkid
Would there be a more beginner freindly version out there.  I've built the beginner project, and I actually have just finished a 4 channel mic pre, but that document ins kinda confusing.
seanm
I think you just want a simple boost pedal. i.e. One switch and a volume pot?
If you want a pcb, for a fat boost, try Jack Orman's mini-booster. For a clean boost try his mosfet boost.
For an even simpler boost, I have had good luck with the utility boost. It can be found here: http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html
Khas Evets
If you want a simple build to act like the volume on you guitar, you just put a pot in a box. When the pot is on you'd have some attenuation and when it's bypassed you'd have full volume. You could also add a cap across the pot to retain highs.
bwanasonic
I guess some people like having this on a switch, but I find a volume pedal to be much more versatile. When using a guitar with a single master volume (strat / tele) I often just use that. If you search the archives here, you should find a diagram for a *volume-pot-in-a-box* as you described.
Kerry M
Dragonfly
Quote from: PtownkidI want to build a volume boost box that'll take my amp from cleanish to normal.  What i mean is, I want one setting to act like you have the volume turned down on your guitar, and then when i press the switch, it allows the full volume to come thru.
here you go...easy build....  :)
andy
dragonfly fx
aron
Good job. Couple of points....
I guess I would make the "bright" cap optional since it might alter the tone of his guitar and possibly use a 500K pot instead of 250K only because he might have humbuckers with a 500K volume pot.
Dragonfly
j0shua
absolutely correct....
when i drew it up, i was going for a "should sound good with all guitars" kinda thing...
but theres certainly lots of room for "personalizing" it to your rig :)
andy[/quote]
Hey Andy can i draw in PCB wizard ? ....
and i like to see whit no 3DPT ....  just a DPDT
DPDT is the only Switch i can get here
Just run the output of the booster to one volume pot or the other volume pot using a DPDT to get the signal in and out of one pot or the other ?
 Run another DPDT for Bypass, and you have three volume presets,
 1: guitar volume knob > Thru bypass
 2: Booster Volume 1 [this is nice cause you can dial that sound like volume control output/normal booster operation]
 3: Booster Volume 2 [can be set higher/lower than Vol 1
 Between these and the guitar knob you should be able to preset pretty well.
 I've never tried it, don't see why not.
Dragonfly
Quote from: petemooreJust run the output of the booster to one volume pot or the other volume pot using a DPDT to get the signal in and out of one pot or the other ?
ive been building a cutter/booster combo pedal thats been pretty popular...sparkle boost on one side, clean machine on the other. its great for 1 channel amps, like marshall jmp's....set up your regular rhythm tone, then set up a "clean" tone with the "cut" side, and a boost  with the SB....gives 3 "channels" from a 1 channel amp....
andy
Dragonfly
Quote from: j0shua
a DPDT will work fine, though you'll have to use something like millenium bypass to have a LED *AND* keep it true bypass.
how would you draw it in PCB Wizard...theres no PCB ? just a pot, a switch, a LED, jacks, a cap, and a power jack ...
just wondering :)
andy
Ptownkid
Wow, thanks for all the replies guys.
What is the topmost part on the clean machine?
Dragonfly
Quote from: PtownkidWow, thanks for all the replies guys.
2.1mm jack...shown from the "backside", so its easy to wire ...when you see one, you'll know why showing it t his way makes it easy :)
if you dont need the LED, you can do away with the battery/power jack altogether...but i find the LED to be very useful...
andy
Ptownkid
I'm alittle confused.  What is a power jack exactly?
Dragonfly
Quote from: PtownkidI'm alittle confused.  What is a power jack exactly?
its a receptacle that you plug a power supply into..the one shown on the diagram will work with a standard Boss PSA-120 adaptor.  i just allows you to power the pedal without  the use of a battery.
if you don't need a "on/off" LED, the power jack and battery are unneccessary...
andy
LeeM
hmm i a little confused, how would i make that with just a DPDT and no led? :?
thanks
j0shua
you can put a led on DPDT , just need to use Millenium Bypass :)
Dragonfly
Quote from: LeeMhmm i a little confused, how would i make that with just a DPDT and no led? :?
thanks
you can find BOTH versions in my folder in the Layouts Gallery !
heres a link...
http://aronnelson.com/gallery/album20
andy
