Torchys MXR Wylde - Boxed up!
Started by kojjum, April 13, 2005, 10:29:58 AM
kojjum
MXR Wylde clone, stripboard layouted by Torchy! Thanks a lot...what a excelent sounding overdrive this is. So sweet and Zakk soundnig if you whant to.
This is my almost finished box:
//jens
Never repair stuff that ain't broken!
Marcos - Munky
WOW!!!! Now that's a really beautiful box.
LivingDeadPunk
Excellent!  :shock:
What kind of decal did you use for the upper side?
Technological progress is like an axe in the hands of a pathological criminal.
Albert Einstein
vanhansen
That is sweet.  I like the design.  Good work.
This is my favorite overdrive pedal now. =)  The SD-1 has moved aside.
Erik
Clipped
To Each His Tone.
Very pretty.  Nice work.  Captures the spirit well without stepping on copyright toes.
Prompts a question though.  I have also placed adaptor jacks on the side, though I tend to prefer them on the rear skirt.  But why did you choose to place the adaptor jack closer to you rather than behind the input jack?  Just curious.  Do you have any regrets?  Or alternatively, do you have a specific system/approach for using power patch cords?
kusi
wow, thats cool.  8)
little question: from where do you have the "zakkifier"-font? it looks very nice... whats the name of it?
greetings kusi
Clipped
Quote from: kusi
Kusi -
I don't about this one in particular, but http://www.fontfreak.com
has a TON of free true type fonts for you to add to your projects.
Ron
To Each His Tone.
TBA
 Where's the schematic for this one?
vanhansen
Quote from: Clipped
Quote from: kusi
Kusi -
Ron
The BLS font is Old English.
Erik
kojjum
Quote from: LivingDeadPunkExcellent!  :shock:
I Use a transparent vinyl sticker in A4 format that I run trough my office colorlaser printer. I have both white and transparent vinyl...in this case I used the transparent becuse the box was white.
//jens
kojjum
Quote from: Mark HammerVery pretty.  Nice work.  Captures the spirit well without stepping on copyright toes.
I usually put the adaptor jack on the "north end". In this case I would like to have the pots in one line and as faar north as possible for the graphics and to make sure that it was enough room to fit the stripboard.. I'm not sure if it was such a good idéa to put it there but it will show.
//jens
kojjum
Quote from: kusiwow, thats cool.  8)
greetings kusi
I don't remember the name...i'll check my Illustrator document when I get to the office tomorrow morning.
//jens
I looked but didn't see...is the schematic in one of those links?
kojjum
Quote from: petemooreI looked but didn't see...is the schematic in one of those links?
Look here:http://forum.musikding.de/attachements/MXR_ZW-44_Wylde.jpg
//jens
Thanks Kojjum !!!
kojjum
Quote from: petemooreThanks Kojjum !!!
You are welcome!
//jens
WGTP
The MPSA14 is a Darlington transistor.  Does that make since for an input buffer?   :?
Stomping Out Sparks & Flames
I don't see why not...I used a 3904 after frying a HG/LN transistor or two trying to darlingtonize them. Works PDGood too !!!
 Definitely quite lively sounding !!! Just finished getting it going !! A little messy, I decided to go by the pin #'s, but at least it's pretty tight, I managed to not make it super gangly anyway, but should have either started with Pin 3 as input or turned the Opamp around.
 For the voltage divider on this one I used two 22k's and a 20k trimpot inbetween and I'm able to move the 4.5v bias around a little bit.
 Interesting pedal, I think I'm gonna like this one.
G Kresge
