PAIA Gator op amp question
Started by primalphunk, April 17, 2005, 09:52:56 PM
primalphunk
I built a PAIA Gator from their kit that I was given for my birthday.  It uses an LM308 op amp.  Is that a dual op amp with standard pinouts like an JRC4558 or NE5532?  If you've ever built one of these do you know if I can safely start swapping op amps?  It seems like I should be able to but I'm just dumb enough to have my doubts.
Thanx in advance for any help that can be given.
peace,
James
The LM308 [used in Rats] is a compensated opamp, the standard duals are not substitutes, in my limited tests of swaps they didn't work.
toneman
elaborating on Pete's comments--
the 308 is a single OA.
the 5532 is a dual OA.
*totally* diferent pinout/animals.
"uncompensated" means U have to add a compensation cap.
usually across pins 1 & 8.
if U got a kit,  it should work.
Paia has been producing this kit for 20yrs.
it's a noise gate, so shuts off when U R not playing.
why would U want to "swap" the OA??
stayworking
tone
Actually, the 308 is an uncompensated op-amp.  I think what Floyd/Pete wanted to convey is that it NEEDS to be compensated externally (cap between pins 1 and 8) to function appropriately, since the internal compensation is not present as it is on many other op-amps.  Easy terminological mistake to make.
Depending on the role the chip is expected to play inthe circuit, it can be subbed with a compensated op-amp...or not.  Typically, designers use compensation for specific reasons.
I've found PAiA to be very responsive to inquiries in the past.  If you have any concerns, feel free to give them a shout.  Who knows.  There might be a chat with John Simonton himself in there somewhere.
