Strange LittleGem
Started by SuperGeo, April 20, 2005, 01:20:57 PM
SuperGeo
Hello guys
I built the LittleGem MKII, it worked and I thought it very nice amp nice overdrive while driving the 386 with more signal but yesterday I wanted to play guitar but my LittleGem was veery strange! It distorted very easy and it sounded very bad... If you kept letting more signal do the 386 it created a noise like a Bus Horn! Its very unpleasn't sound :(
Anyone has anyidea of what's going on?
thanks
Paul Marossy
Are you using a 9V battery? You may have drained it to the point where the power supply isn't enough to drive the circuit. It doesn't take too long to eat up a battery with a pair of LM386s...
SuperGeo
i'm using a regulated power supply
I recorded a sample .wav of my problem:
http://s42.yousendit.com/d.aspx?id=0Q07NQKD2P88G21Y4LFHHZPOR8
Paul Marossy
Hmm... that's weird. I don't have any ideas on that right now. What voltage are you running it at? The N4 version has a higher operating voltage capability than the ones that RadioShack sells. Maybe you fried the chip or something?
SuperGeo
just forgot to say, the second part of the clip I was turning the pot
maybe I could fried the chip :S
I'm running it at 9v
Paul Marossy
Strange. Maybe someone has had this strange experience? Anyone?
Pedal love
SuperGeo
I have no DMM here, but I will check for shorts when I get one
Another thing I found. That horn sound that comes from nothing when I turn the volume pot only happens when I touch any metallic part of the potentiometer but the sound continues worse!
ideas?
Paul Marossy
Perhaps a connection to ground has come loose?
Pedal love
Sounds like ground, keep checking the wiring.pl
Pedal love
Something is not connected properly.  The chip could have a problem but I'm leaning toward connection trouble.pl
Paul Marossy
I'll bet on a faulty wiring connection as well.  :wink:
Pedal love
Probably a connection or one of the components or the power supply. :wink:
SuperGeo
I found the problem!
every single conection to the ground was right
I tried swapping the IC's but nothing changed.
Then swapped the Transistor e voalla! Nice clean sound again!
Something I saw now, when using my Gt-2 made by me with Little Gem, when volume it's like in the middle a noise starts do appear :S
