Author Topic: Boss DS-1 mod. (more midrange)  (Read 5284 times)
vajhoj
« on: April 22, 2005, 10:24:48 AM »
Hey everyone.
I'm new here, and let me just say: What a great site!!!
I have a question about mods. for my Boss DS-1.
I would like to get a bit more midrange tone. And lose some of the (to me) screaming hi-frequency.
Would I get this with the Anolog Man DS-1/Pro mod.?
Does anyone have schematics, component-lists etc. for this mod.?
Best regards from Denmark
Michael
Guitarist from Denmark
« Reply #1 on: April 22, 2005, 11:33:40 AM »
Fuzz Central has DS-1 mods...
vajhoj
Re: .
« Reply #2 on: April 22, 2005, 11:38:37 AM »
Quote from: petemoore
Doesn't the Fuzz Central mod. make it a bit more Heavy-sounding?
I'm in for a more blues-&/rock n roll- like sound.
br.
Michael
Melanhead
« Reply #3 on: April 22, 2005, 11:48:58 AM »
have a listen to mine ... that's what I tried to do ... more mids :)
http://diystompboxes.com/sboxforum/viewtopic.php?t=32443
MartyMart
« Reply #4 on: April 22, 2005, 11:54:52 AM »
Hi and welcome !
Have a look inside at the circuit, see which section is connected to the
"tone" pot ..... you can make changes there to loose some "top" end and
re-voice it for a bit more "mids".
Doing this carefully will be fun and you'll learn something...
Bigger value caps = more low end
Smaller caps = more mid's/ high's.
Also using a small cap ( 2.2nf or 0.0022uf ) from signal to "ground" will roll off some "top" and putting a very small cap ( 47 - 300pf ) across the
pair of clipping diodes will take some harshness off the distortion.
Take a look and see what you can figure out, its not "rocket science"  :D
( or you could just buy the fuzz central info, but where's the fun in that? )
Marty.
Melanhead
« Reply #5 on: April 22, 2005, 12:05:06 PM »
yup .. it's fun to experiment, and you'll get an idea of how signal flows through the circuit and what you can and can't change ...
 ... chances are you have your own idea of the tone you're looking for and tweaking is the only way to get it, as tone is so subjective ;)
I tweaked mine for a few weeks ... It's definitely better but I'm more partial to the milder clipping of an overdrive ...
vajhoj
« Reply #6 on: April 22, 2005, 04:46:48 PM »
Quote from: Melanhead
Hey Melanheld.
That sound just great - I think I'll try that mod out.
Thanks.
/Michael
« Reply #7 on: April 22, 2005, 04:54:20 PM »
You could add a cap to ground or cap/pot to ground to find the amount of high end rolloff control [in addition to turning the tone knob down].
  Because it's a Boss, I'd imagine you'd want to not try adding a pot, using the pot to find the resistance amount you want there, then use a fixed resistor and solder the C and series R [chosen value] in.
  I'm sure there's a LP filter cap or R/C in that circuit, increasing the value of the LP filter cap would reduce highs.
  To reduce lows, choose cap[s in the signal path to make smaller value[s.
  If you LP filter [cut highs] and HP Filter [cut lows] what's left is midrange.
Melanhead
« Reply #8 on: April 22, 2005, 06:39:37 PM »
Quote from: vajhoj
Hey Melanheld.
Thanks.
/Michael
have fun ...
wampcat1
« Reply #9 on: April 22, 2005, 09:45:58 PM »
I have several diy ds-1 mods if you want to go the diy route. I also address the midrange issue (I have labeled what parts to change to give it more midrange for example).
I also have free mods when you join the newsletter list (All you have to do is send an email to info@guitartone.net and you will be sent an email confirmation).
Take care,
Brian
vajhoj
« Reply #10 on: April 23, 2005, 08:08:58 AM »
Quote from: wampcat1
Take care,
Brian
Well then. I've just joined - looking forward to the DIY-mods.
« Reply #11 on: April 23, 2005, 09:45:02 AM »
Them Tone knob circuits...you can either turn the knob or change a part and get nearly the same result sometimes...makes so you should try to sort that mentally [without going too mental on it...unless you're an EE...whoops lol]...you'll surely find that the voicing parameters can be moved around...
  I've socketted parts around tone knob...
  H'eres my two cents theories...a little of one or the others may do something liked...
  Decrease bass input [smaller incap or SP cap] and turn the tone knob down....
  Attenuate high with SP to ground cap...turn the tone knob up.
  Mess around with values that directly influence the function of the tone pot.
  ...not necessarily or in that order...
  When I get enamoured by a circuit, I'll double it, then have two tweeks that I can instantly A/B to compare...AAAGHhhhh...try someThing else on this one ???...it's lacking * compared to that one...
vajhoj
Re: ./
« Reply #12 on: April 23, 2005, 09:50:28 AM »
Great point!!!
