What to use for BSIAB
Started by critch, April 26, 2005, 07:02:46 PM
critch
Ok, im gonna build the BSIAB II pedal, but what compnents do i use? when i have a choice i mean.
http://www.generalguitargadgets.com/bom/bsiab2bm.txt
DPDT or 3PDT heavy duty foot switch, which one?
and should i change the input jack into one of those switch ones? so that the circuit will be off when its not in use.
And i want distortion like arch enemy(and similar bands) use...so should i use all 2N5457? thats what ive heard?
thanks
Any other advice when building the BSIAB II?
DPDT for true bypass
 3PDT for TBpass w/ LED Indicator [the easy way]
critch
ok, so ill use the 3PDT, coz i want an LED indicator....
and what about the 2N5457's? whats the difference when i use all 2N5457, and when i stick to what the schematics say?
mlabbee
Transistors are cheap!  Put in sockets and try the different combos that have been written up on this board - that's half the fun! :D
I never tried but think those are nice Fet's.
 Sockets for Fets are nice cause they vary, unit to unit, and brand type.
 Should work fine !!
gotdabluz
I socketed mine and currently have all 2n5457's in it . . .
think Aron has a design called the Booster 2.5 which I believe is a forerunner to the BSIAB (cascaded miniboosta stages) . . . it uses all J201's
not a huge tonal difference between the 2n5457's and the J201's, though to my ears the 5457's are a little smoother
YMMV and since those FETs are so cheap, you can afford to experiment
you want to buy a bunch extra anyway, in case you accidently fry one or catch a piece that is a little wacky . . . I had one that screwed up the whole biasing of my circuit until I (with the help of petemoore and EdG) tracked it down and replaced it
best of luck
--SG
critch
ok, so ill just experiment....
and im thinking of using a DPDT instead of a 3DPT, it seems it will be MUCH cheaper. will this make the GGG schematics harder for someone like me?
Ed G.
You can use a dpdt, it will give you true bypass without the LED function. Not a big deal for most people.
Albert Kreuzer
You can still add a Millennium Bypass from www.geofex.com later (and keep the DPDT switch - I built several variations from R.G.'s site and they all work great.
Cheers,
Albert
Everything works until it doesn't.
critch
ok so im gonna ditch the 3DPT, and does anyone know if GGG are reliable for PCB's?thinking of ordering my BSIAB II PCB from em...
thanks
gotdabluz
I'm not gonna dis GGG . . . I've heard good things
but why not just get a piece of vero (stripboard) and use Torchy's layout?
I can verify that it works . . . my first build with his layout worked like a charm (except for that pesky jfet I mentioned) . . . and . . . if your components are a little oversized (fat film caps, etc), you can stretch the layout accordingly if necessary.
either way, I think you will be pleased with the circuit.
Good luck!!!
--SG
Hal
Aron sells 3pdt switches for like $6.50 or something like that.
The Carling DPDTs are like $8.  I hear bad things about the cheaper dpdt's, like the x-wings...
It might be cheaper to do 3p's in the end...
critch
ok, components sorted, but can anyone tell me what components can massively define the sound? im thinking of aading switches for some components, to make the pedal more versatile
syzygy
What is in Arch Enemy's guitar rack?  The BSIAB II is more of an Eddie Van Halen tone..  did you notice a similarity in their sounds?  I think Arch Enemy has a tighter, scooped mid sound for metal.
critch
i cant see any tone defining pedals, or distortion pedals in their equipment list.
and any van halen songs in particular?
syzygy
Quote from: critchand any van halen songs in particular?
Don't remember the name of the song, but check both clips on this thread to see what I'm talking about.  One of the clips is less EVH than the other, but part of one clip sounds like "Girl you got me..".  Also keep in mind that this guy was running his BSIAB through a Bogner Xtc preamp.  :shock:
critch
sure, but along with this pedal, i will also try and find a death metal pedal to build, both will go to very good use!
RDV
I still say that death metalers do NOT use pedals.
RDV
vanhansen
Quote from: syzygy
It's "You Really Got Me".   :roll:    :D
Erik
vanhansen
Quote from: RDVI still say that death metalers do NOT use pedals.
RDV
There are a few commercial pedals out there, Digitech has 1 or 2.  But I tend to agree here somewhat though.  I'm not a death metal person but I would guess that some of the bigger players use rack mount systems.  Some of those racks got some seriously sickening gain.  I'm thinking Sepaltura, Napalm Death or Cannibal Corpse type sound.
Erik
