buzzing microamp???
Started by samuelk, May 02, 2005, 07:45:41 PM
samuelk
i´ve just finished my first stompbox project with almost 100% success.  when i crank up the microamp at about 3-4 o´clock and sitting very close to the amp with the guitar it sounds great. but when i get up and move away from the amp it starts to buzz very loud. i don´t even know if its the microamp thats causing it. somebody know whats causing this very unpleasent buzz?
aron
Is it boxed up in a metal enclosure?
What kind of guitar/pickups??
Tony Forestiere
Check your guitar cables/jacks/connectors :cry:
samuelk
yeah it´s a metal enclosure but i´ve tried without it and it makes the same noise.
samuelk
plzzzz can´t someone figure out whats wrong
JimRayden
Maybe the amp just likes you. :D
I'd say, yes, check the cabels and secure them from moving.
Jimbo
davebungo
This may be silly, but when you get up and move away from your amp, are you, per chance, moving towards something else (like an 11kV transformer or something obvious like that)
Roberto
maybe your metal enclosure is not grounded. Are you using isolated jacks?
samuelk
roberto
i´ve tried  it without the enclosure and the buzz remains
Roberto
well, if you try the circuit without enclosure usually you get hum. If you try                             the circuit inside a not grounded metallic enclosure, then you get hum too. But if you try your circuit inside a grounded metallic enclosure then the hum could be eliminated.  I was thinking your enclosure was not properly grounded because you get the same hum with and without it.
English is not my mother language, I hope you understand me :)
Regards.
samuelk
i arranged it properly in the enclosure and now it seems to work just like i want it to =)
