Making enclosures
Started by mojotron, May 03, 2005, 11:50:25 AM
jmusser
I love the blue box (looks a lot like the original), and the lettering, really nice job! That thing is built like a tank! I guess if the effect doesn't work, then you can always use the box for a car ramp for changing your oil :lol: Is the channel something you make, or something you buy? If you're building this yourself out of 1/8" aluminum plate, then you have access to tools that very few of us have. You would need a fairly hefty break, shear & notcher to make it from scratch. I have worked in metal fab, so I know what it takes to make something like that from scratch. The tools are expensive too!
Homer: "Mr. Burns, you're the richest man I know"            Mr. Burns: Yes Homer It's true... but I'd give it all up today, for a little more".
wiplash
QuoteI love the blue box (looks a lot like the original), and the lettering, really nice job! That thing is built like a tank! I guess if the effect doesn't work, then you can always use the box for a car ramp for changing your oil  Is the channel something you make, or something you buy? If you're building this yourself out of 1/8" aluminum plate, then you have access to tools that very few of us have. You would need a fairly hefty break, shear & notcher to make it from scratch. I have worked in metal fab, so I know what it takes to make something like that from scratch. The tools are expensive too!
Thank you, I've built it for my father who have a garage :lol:
I'm really started from scratch, with a 2mm aluminium plate (~0.08 inches), you dont need a lot of tools, I've used metal saw,hammer,(shear, but the saw is sufisant) and a vice (something to block the aluminium plate for bend), abrasive paper to sandpaper...and patience...
you can try with 1mm plate...
for the lettering I've paint with my owns two hands 8)
Sorry for my english lol www.techniguitare.com
wiplash
photos of the building...It's not hard but need work.DIY!!!!
ESPguitar
Quote from: wiplashphotos of the building...It's not hard but need work.DIY!!!!
Did you weld anything at all?
RB
wiplash
no  welding it is just folded
jmusser
I've done stuff like that before too, but mine NEVER came out that well. Mine usually looks like it was bent in a vise, and has teeth marks from the vise jaws. I could make it look that nice with a brake, but definitely not with a vise. You have a gift my friend!
rubberlips
Quote from: wiplashIf you use metal like iron you can weld, but the aluminium is difficult if you are not specialist.
Depends on your welding gear I guess. I've got a gasless mig at home, you can buy the gasless aluminium welding wire for it as well, almost like soldering :)
It's probably quicker and easier to do a bit more bending and less welding
Pete
play it hard, play it LOUD!
wiplash
QuoteI've done stuff like that before too, but mine NEVER came out that well. Mine usually looks like it was bent in a vise, and has teeth marks from the vise jaws. I could make it look that nice with a brake, but definitely not with a vise. You have a gift my friend!
to avoid the marks of teeth I use wood boards between the jaws of the vice ,and abrasive paper to finish if there is some marks, and the paint mask the imperfections 8)
QuoteDepends on your welding gear I guess. I've got a gasless mig at home, you can buy the gasless aluminium welding wire for it as well, almost like soldering
I never tested this :wink:
Paul Marossy
That's some nice work on that blue box!  8)
Hal
wow.
whats the Al from?
wiplash
My tyco is finish look:
8)
