High Gain Pre-amp
Started by ESPguitar, May 07, 2005, 06:41:06 PM
ESPguitar
Hi,
I want to build myself a pre-amp it don't have to be more than one channel.. But i need HIGH gain..!!
Dimmu Borgir and Children of Bodom tones (i play more Bodom than Dimmu)
All ideas are welcome.. Schems?
Thanks,
RB
ESPguitar
Steben
hmm let me think...
does it have to be tubes?
i don't have the dimmu borgir sound in my head...
don't forget equalizing before and after a distortion device can bring a lot of voicing.
Build one...
 The PS is the 'hard part' for me, the 'circuit part is about the same as wiring a distortion or Jfet Amp sim. Maybe you have an output amp with high voltage on the tube that you can use as a preamp PS Tap....and the unusual warnings that you can kill yourself messing with big tube amp innards.
davebungo
Quote from: ESPguitarHi,
Thanks,
RB
The AMZ Minibooster (based on a high gain FET mu amp) should do the trick.  I take it you are driving a valve amp.
ESPguitar
Ok let's say the Hi Gain lead channel on a ENGL amp..
That is the type of sound i'm after..
RB
12afael
Marcos - Munky
Build Ricky's Heavy Metal Pedal and add a good EQ. Or use Zakk Wylde's trick, add a overdrive to a distorted amp.
Steben
Quote from: 12afaelthis is a great preamp
http://www.alejandrosilva.cl/equipos/PS_4.jpg
Still, I prefer logical, simple preamps (this feaures 3 channels right?)
by the way, preamp tubes come in doubles (2 tubes in each component) so i prefer "even" designs.
Also, High gain distortion is not begging for tube circuitry, I mean it's not the holy grail like it is for power amps (medium gain - blues etc...).
A good stompbox or FET booster can do the trick.
