LED/LDR for tremulus lune
Started by shawsofhell, May 20, 2005, 09:05:04 AM
shawsofhell
i am building a tremulus lune and would like to know what is the most appropriate led/ldr pairing to use?
keninverse
any cds cell with a ~5Klight and 500K or more dark should work.  As far as the LED is concerned it shouldn't really matter b/c of the current limiting trimmer.  Try a vactrol if you have any.
ken
Fret Wire
Fret Wire
(Keyser Soze)
80k
try a rectangular Red LED.  that is the easiest to tape to the photoresistor.
shawsofhell
will a standard red LED be sufficient to work with the LDR (500k to 5K)?
keninverse
yes.  but label the leads and try to put some heat shrink or tape around the led/ldr combo.  this way the combo will stay together if the the pedal gets bumped around.
