OT Question: Blowing Fuses?
Started by pjackso, May 29, 2005, 04:41:55 PM
pjackso
Totally off topic I know, but my amp just started going through fuses like tic-tacs. :?
It makes a few terrible sounding pops and then a huge BAM when the fuse blows... :x
Its a well used 75' Twin Reverb.  I should mention that I cannel jump the Normal and Vibrato together.  I'm not sure if that has anything to do with it.
Any help would be greatly appreciated :D
The Tone God
Well if your consistantly blowing fuses then you have issues and no I don't think the channel linking has anything to do with it.
Check your tubes. You might have a bad tube in there most likely a power tube. If they check out then something is going on inside. Unless you are well versed in handling high voltage you might want to hit a amp repair shop.
Andrew
cd
Most likely a bad power tube, but next time, check this out:
http://geofex.com/ampdbug/ampdebug.htm
Steve C
My Super Reverb was doing the same thing a couple of years ago, turned out to be a bad rectifier tube.
