Marshall VT1 VibraTrem
Started by jbm222, June 09, 2005, 11:18:37 PM
jbm222
I have one that a friend gave to me a while back because it was broken.  First thing I need to do is put a switch on it, see what sounds (or lack there of) come out of it, to get an idea what's wrong.
But this first thing I need is a schematic.  Does anyone know where I can find one.  I'm sick of wading through all the google results that are trying to sell me a pedal.  I haven't had any luck at all tracking down a schematic.
Also, does anyone know of common problems with this thing?
It has a few trim pots in it, but I can't tell what they do because I haven't taken the time to trace any of the circuit.  It's really pretty complicated, and would be worth the time needed to trace the whole thing.
wampcat1
I haven't found one either - if you do find one, would you mind emailing me a copy?
Thanks,
Brian
brian @ indyguitarist.com
jbm222
Quote from: wampcat1I haven't found one either - if you do find one, would you mind emailing me a copy?
Thanks,
Brian
sure, no problem.
I guess I could try emailing marshall.  I've had a few companies cooperate that way.
