SFT353 transistors
Started by Xavier, June 10, 2005, 09:12:23 AM
Xavier
I have just found at our service department a box containing several old Ge transistors, this one catched my eye since it's shaped like an AC128. After searching a little bit , in one of these datasheet pages I have found the description "Eg NPN low-power BJT", which is the same the OC44 has :shock: .
Does anybody know if they are close, can I use them for building a FF or similar pedal?
Joe Kramer
Hi Xavier,
FWIW, I have tried SFT352 for FF and it sounded pretty good.  If the ones you can get are cheap, might as well take a chance.
Regards,
Joe
Solder first, ask questions later.
www.droolbrothers.com
