Tone Bender More Volume?
Started by Arn C., June 14, 2005, 09:34:18 AM
Arn C.
Howdy all,
 I recently built a tonebender which sounds excellent with my humbuckers, but I would like to put a tiny circuit (clean) to boost it up a bit for single coils, something I can switch in and out depending on the guitar I use.   Any recommendations would be appreciated!
Arn C.
Bernardduur
Check out the Mindbender at Fuzzcentral. By replacing the 470 ohm resistor with a 1k2 resistor it makes the unit boost; I have mine switchable (but set it like always on the boost setting).
Am learning something new every day here
SquareLight | MySpace account
Arn C.
Thanks Bernardduur!  I will check it out!
Peace!
Arn C.
RedHouse
Got a link? I went over there and didn't see a "Mindbender"
Bernardduur
squidsquad
Also...I once built a weak fuzz...then slapped a simple Fetzer Valve circuit after it (from ROG) and that really worked well.
RedHouse
