Wah Wah Buffer Woes...
Started by STOMPmole, June 27, 2005, 03:59:07 AM
STOMPmole
I've got a Roger Mayer wah with a Roger Mayer Classic Fuzz and I've been trying for years to successfully run my signal path as Guitar>Wah>Fuzz>Amp.  It just doesn't work...the wah has no effect when running it into the fuzz.
I've also read all the forums and done searches which recommend using a buffer.  I've tried 3 different buffers (Boss pedal, TC Electronic, and DIY FET buffer) both before and after the Wah and it still doesn't work properly and sounds strange when plugged in pre-fuzz.
Can anyone tell me what the problem might be or a possible solution??
From what I've read and seen in pictures nearly everyone runs their Wah before the Fuzz Face, most notably Hendrix.  How did Hendrix manage to use a Vox Wah in that configuration and get a good tone without running a buffer...and if it was modified by Roger Mayer with a buffer why in the #$^% doesn't my Mayer Wah and Fuzz work that way???
I'm open for any solutions including Wah replacement if necessary!
Thanks in advance~!!
mrsage
You should try building a buffer designed for a wah.
Check under the Vox Clyde Wah project on Fuzz Central:
http://fuzzcentral.tripod.com
It shows a sample output buffer that will help your problem.
formerMember1
http://fuzzcentral.tripod.com/axiswah.html
this is a good site, maybe it will help.
PS:these effects are not roger mayer effects, this guys pedal company is axis pedals.  they are not to be confused with roger mayer's axis fuzzface.
the site still talks about a buffer though, and there is pictures.
hope this helps man
MacHeath
Looking for ways to add an output buffer to my budda wah, I found this thread. Here's the current link to the axis wah on Fuzz Central: http://fuzzcentral.ssguitar.com/axiswah.php
Kevin Mitchell
But... you wont get the orcha effect when plugged in backwards...  :icon_cry:
My experimenting from last year
Nothing crucial. Just a little wah madness you might find interesting  :icon_cool:.
This hobby will be the deaf of me
drummer4gc
You might try a 10k resistor in series with the output of the wah. It's worked for me in the past.
