Delay stompbox mods - Ibanez DL5 and DOD DFX9
Started by Simonetta, July 19, 2005, 12:08:46 PM
Simonetta
Hello,
 I found that the popular Ibanez DL5 soundtank delay can be easily modified to double its short delay time.
 This device has a special Karaoke Echo IC to make delay that uses sigma-delay ADC instead of SAR ADC.  It uses an old single DRAM chip for sound sample storage.
 By 'piggybacking' a second chip on top, and connecting the out of the 1st to the in of the 2nd, the delay time is doubled.  This is a common 4164 type DRAM that sells for less than a dollar.
 I suspect that all delays that use a single bit DRAM (with seperate data in and out pins) can be modified in this way.  The DOD DFX9 also uses a design like this.
ExpAnonColin
Simonetta,
I posted your DL5 mods on the archives here
http://www.experimentalistsanonymous.com/diy/Schematics/Circuit%20Bending%20and%20Modifications/Ibanez%20DL5%20mods.pdf
if anyone is interested.  Great file.  The only one in the circuit bends/mods folder sadly :(
-Colin
