MXR Zakk Wylde questions
Started by Fumi SG, July 24, 2005, 03:24:00 PM
Fumi SG
I just printed out the schematic of the MXR ZW-44 for a friend. There I noticed there are some parts connected to 4.5 Volts, but how do I get 4.5 Volts since it works on a 9V battery or adapter?? Do I get the 4.5 Volts with the circuitry shown in the lower left-corner (in the blue circel)??
I've put the parts that are supposed be connected to 4.5 Volts in a red circel...
->here is the schematic<-
puretube
Fumi SG
so the 4.5Volts parts should be wired ->this<- way, right??
puretube
precies!
(the red circle "makes" the 4.5V;
the arrows labeled 4.5V "need/use it").
Fumi SG
Then I had some other questions about this one. What do the numbers at the in- and output (1-5) and the accompanying arrows mean??
And another question. What are you supposed to do with '4' and '8' in blue-circeled bit (that converts 9V to 4.5V)?? You see a wire and it's interrupted, how do you solder that??
-If I knew I'd tell you. I've never seen 'em like that and can't make much sense of them.
 I'd ignore the numbers and wire the circuit board, then add the DPDT or 3PDT switch and jacks.
 There's a picture of true bypass wiring examples at AMZ iirc.
Branimir
um, is that a TL072 or something else, i fail to see where the IC's name is on the schem ;)
hm.. this thing looks like a mxr dist+ ;)
Umor
Built: Fuzz Face, Small Stone, Trem Lune, Fet Muff, Big Muff (green), Fuxx Face, Son of Screamer, Rat, Rebote 2.5, Opamp Big Muff, EA Tremolo, Easyvibe, Axis Face Si
gaussmarkov
Quote from: Fumi SGThen I had some other questions about this one. What do the numbers at the in- and output (1-5) and the accompanying arrows mean??
i believe the numbers on the in and out are the pin numbers for a surface mount jack.  And the 4 and 8 probably refer to pins 4 and 8 of the ic.
Fumi SG
Quote from: Branimirum, is that a TL072 or something else, i fail to see where the IC's name is on the schem ;)
hmz... it says PPEA 33178 7 U1B, and (there's another one!) PPEA 33178 1 U1A. Anyone?? :P
@gaussmarkov... so I can just ignore the numbers on the in- and output jacks?? And you say '4' and '8' refer to the pins of the IC, but which IC??
MartyMart
Quote from: Fumi SG
There's only "one" ic , its a standard dual opamp, such as : 4558/NE5532
TL072/OPA1324  etc etc, they have 8 pins which supply "two halfs" or
two "single" opamps in one small package :
Pins 1/2/3 and 5/6/7 are wired like the schematic, pin 4 will connect to
ground and pin 8 will connect to 9 volts.
That's what it means on the schem, O1A and O1B are the two "halfs"
Cheers,
Marty
Fumi SG
so the schematic shows two symbols, but in fact there is just one single IC...Thanks! You've explained it VERY well! :wink:
gaussmarkov
Quote from: Fumi SG
yep (except i should of said "pcb mount" instead of "surface mount")! :D
