Found transparent adhesive decals for Injet in Canada!
Started by Melanhead, July 26, 2005, 06:53:17 AM
Melanhead
Well, I've been playing with the idea of decals for some of the pedals I'm going to build but was having a hard time finding anything in town that was transparent and adhesive...
Well here's what I found ...
Staples stocks this : "Xerox Window Decal Film For Inkjet/Bubblejet Printers" ... It helps when you explain what your looking for to a helpful staff member. I usually wonder around a store thinking I could find it myself. Been to Staples 5 or 6 times wondering around before I asked! DOH!
Works very well ... will post pix of the new decal pedal when it's done.
I'm still looking for a similar adhesive ( not water ) decal film that's usable in a laser printer if anyone knows of any.
sir_modulus
Fret Wire
I can't seem to locate it on either Staples' or Xerox' websites. Does it have a model # or product code?
Fret Wire
(Keyser Soze)
Melanhead
I couldn't finb it online either ... very weird indeed but it's called Xerox Window Decal Film For Inkjet/Bubblejet Printers ....
I'll check when I get home, I'm assuming it has some part or model number.
BDuguay
This is good news! Thank you fellow Canuckian.
Now I have to decide whether I buy a new printer head for my older, but probably better, Canon printer or, for about 20 bucks more, buy a new Canon printer that will likely need replacing in a year.
B.
spudulike
I use inkjet only media (decals and transparencies) in my Konica-Minolta laser printer with no problems. I always select "heavy stock" setting and keep the temperature down.
Melanhead
Quote from: spudulikeI use inkjet only media (decals and transparencies) in my Konica-Minolta laser printer with no problems. I always select "heavy stock" setting and keep the temperature down.
Hmmm ... that's good to know ...
Melanhead
re-order # 544P15711
it's called "Xerox Color Inkjet Window Decals" on the package.
Found some today.  NOT cheap!  Priced at roughly $13.50 for 5 sheets.  One of those things where one saves up a bunch of images that one wants to print, and then you run off a big job.
Melanhead
Quote from: Mark HammerFound some today.  NOT cheap!  Priced at roughly $13.50 for 5 sheets.  One of those things where one saves up a bunch of images that one wants to print, and then you run off a big job.
Yup :)
Fret Wire
Thanks, I'll check it out. :)   I'm always on the hunt for better decal systems.
Fret Wire
(Keyser Soze)
Melanhead
it's funny but now that I've found 'em I may just keep on hand painting them ... I like the look  ... maybe a hybrid of the two! ...
I did make decals to stick on my modded pedal and they look great!
ezanker
Melanhead
Quote from: ezankerHow do the edges look when you're done?
Sorry for the late reply ... they look great! Check here :
http://diystompboxes.com/sboxforum/viewtopic.php?t=35960
