something to starve voltages for fuzzes (with psu)
Started by Narcosynthesis, August 19, 2005, 08:50:54 AM
Peter Snowberg
If it were the impedance raising as the battery dies, I would think every circuit built with a big cap across the supply would be essentially immune that effect thanks to the impedance of the cap. Is this the case?
I always thought it was the voltage and instantaneous current availability over time.
Eschew paradigm obfuscation
To a first order, yes, it is the internal impedance and decoupling does help with the problem of high supply impedance.
To a second order, the voltage and impedance changes speed up as the battery gets closer to exhausted. I believe that is what you're calling "instantaneous current capability over time".
The "instantaneous current capability" is, of course, just the effective series resistance. The "over time" part is (I think) the change in impedance and voltage.
At least I'd model it that way.
