mth5044
DAMN that dual reverb is nice.
Govmnt_Lacky
aflynt
Quote from: Govmnt_Lacky on April 18, 2012, 03:11:01 PM
Quote from: aflynt on April 18, 2012, 02:56:54 PM
Thanks! It's 16AWG Alpha tinned bus bar wire. This stuff:
http://www.mouser.com/ProductDetail/Alpha-Wire/295-SV005/?qs=iXL3lsaaSSD93GExv%2feNsQ%3d%3d
:o
Dang!! That like $1 per foot for 16AWG wire  :icon_eek:
I just noticed that. :o I bought it back in '98. I don't think I paid that much then. At least I think I didn't.  :icon_confused:
-Aaron
kaycee
Quote from: Rulz-Hernan on April 16, 2012, 09:05:27 PM
My first picture!
From Argentina!
Thats nice and elegant. P90 or 45?
kaycee
Box of wrong that is the Fuzz Factory. Built on one of Poodlebra/pedalparts.co.uk boards, a nice neat little board that soldered up very well.
Running tombstone AC132's in there, have some 128's might try them out as well, but comparisons are hard as you never get the same sound twice out of these things...
Xavier
The Déco-Drive and the Dual reverb are STUNNING !!!!!!  :icon_eek:
here's my latest pedal (after a long and painful debugging). A Diamond Compressor clone for Ian Bairnson from The Alan Parsons project.
Jurassic
Here's my first madbean build: The Cupcake (Orange Squeezer clone).
Check out my site for more info and pics: http://www.jurimusic.com/madbean-cupcake-orange-squeezer-clone/
-Juri
sugonidamaso
Quote from: aflynt on April 18, 2012, 02:07:39 PM
This is a Dual Hermida/GGG Reverb in a 1790NS with AMZ switching. I did a custom board layout for it with tabs and sockets for mounting the Belton DigiLog module underneath. I used 2 separate boards since it was actually cheaper to have it fabbed from Dorkbot that way than do 1 big one for both. I designed it to sit atop my '68 Fender Showman providing reverb for both channels. The graphics are intended to cop the aesthetics of the amp's drip-edge era faceplate.
-Aaron
That is a one sick pedal! Great work! :icon_eek:
" The greatest inspiration is often born out of desperation--so be DESPERATE! "
hardstatic
Quote from: Jurassic on April 19, 2012, 10:44:18 AM
-Juri
Did you polish that box?  It's so shiny!  Nice job.
Jurassic
Quote from: hardstatic on April 19, 2012, 10:47:24 AM
Yes I did! I Used sandpaper (from 240 up to 1200 grit) and then some metal polish. It took quite some time.. Next time I'll do it with power tools!  :icon_biggrin:
Rulz-Hernan
glops
-Juri
Fantastic, and thanks for the polishing tips on your site.  I will try it out next time!
darron
i helped Shaun Klinger from klingercustompedals.com out with the enclosures for these ones... Really can't remember what they all are:
Jurassic
Quote from: glops on April 19, 2012, 05:17:22 PM
Cool! :) Thanks!
Pettol
@darron.
Nice looking pedals! How are those made?
darron
Quote from: Pettol on April 20, 2012, 04:33:40 AM
@darron.
thanks (:
they are all powder coated. the ones with a starburst 3d pattern are air brushed before the powder. the final labelling is co2 laser engraving. we got all of those ones done in one night (:
the lighter metal is exposed underneath, except with the silver one where it's engraved very lightly to burn it into a darker contrasting colour.
Pettol
Thanks darron.
Laser engraving - checked out once. Less expensive than one might think.
Govmnt_Lacky
Quote from: Pettol on April 20, 2012, 12:23:16 PM
If you can find someone who can do it  :-\
Earthscum
Quote from: Govmnt_Lacky on April 20, 2012, 02:23:22 PM
Change that to: If you can find someone who will do it. Lots of places won't engrave things that aren't from their own stock. It's too much liability for them to screw it up. We've had people come in and try to get us to engrave heirloom stuff and we refused because if we screw it up... power glitches, massive ID-10-T error, anything... we have to fix or replace it. The stock we buy is alot cheaper (cheaper... not inexpensive... CHEAP).
Also, not to discourage any more than I may have, you're relying on the guy who's doing the engraving to give a sh** about your project. Most likely you will end up with blackened letters, not pretty ones like Darron makes.
Here's your alternative: Find a trophy shop and have them laser engrave top plates for you. If you go in, you can usually see what the stock looks like. Have your artwork on disk (find out what format you can both be comfortable working in), and write the sizes down. They can round the corners for you, usually. 4.25"x2.25" with a 1/8" corner radius fits nearly perfect on a 1590B. The stock will vary, from translucent coats that shine silver or gold when engraved, to opaque coatings, some with graphic (like marble). Also, they should have plastic that has 2 colors to it. One of the neat ones is about .06" of clear with opaque top sheet. These are awesome to reverse engrave (from the back) and paint with your own colors.
darron
everything Earthscum says is true.
I get very nervous getting the registration right too as sometimes a tiny thing will get overlooked or you'll get a glitch. Luckilly a lot of those enclosure were drilled with jigs of my own making to match the digital artwork, so it was a lot easier.
The plates idea is very good! Talked Shaun into that for the ones that I knew wouldn't engrave well (and yes, I didn't want to mess around with):
They make some for lasers in brushed/ploshed brass and silver colour that engrave black very nicely.
