Author Topic: Pictures!  (Read 7718580 times)
mma_rub and 3 Guests are viewing this topic.
wui223
« Reply #40 on: August 25, 2005, 07:16:39 PM »
Quote from: mojotron
I've had fun with these electrical boxes...
Are the boxes plastic or metal? How u apply the nice finish on them?
warioblast
« Reply #41 on: August 25, 2005, 08:25:28 PM »
Rangemaster & Tone Bender
Gladmarr
« Reply #42 on: August 25, 2005, 08:50:30 PM »
Okay, I know I haven't done much on this forum in a long time, but I have to get in on the picture game.
Interfax Harmonic Percolator with some add-ons.
my sequenced panner that is still getting debugged.
Since we're throwing in amps too, this is a clone of an Orange Overdrive.
Keep 'em coming!!!
ejbasses
« Reply #43 on: August 25, 2005, 10:01:23 PM »
heres a couple of my builds.
Based on the DOD OD250 with different clipping diodes and opamp. Blue MOJO LED  :wink:
DIY power supply. 9.25V @ 200mA
Four Strings To Rule Them All And In The Darkness Bind Them
MartyB
  • Guest
« Reply #44 on: August 25, 2005, 10:15:48 PM »
Wow this thread is so cool!  Ejbasses: is that a homemade drill?
vanhansen
« Reply #45 on: August 25, 2005, 11:18:51 PM »
Ok, might as well join in on the fun.
NPN Boost:
ROG Ruby:
GGG Simple IC Buffer:
ROG Fetzer Valve (guts) - the outside is just the plain 'ole aluminum color:
Erik
ninoman123
« Reply #46 on: August 26, 2005, 12:05:22 AM »
loving the clear box ejbasses
cool amp build gladmarr
Heavner
« Reply #47 on: August 26, 2005, 12:40:02 AM »
Here's some of mine.... more on the way soon!
The older I get... the better I was.
MartyMart
« Reply #48 on: August 26, 2005, 04:58:36 AM »
http://www.pbase.com/martymart/image/48233619/original
Here's some "goodies" - missing about 15 others, which are at another
studio .....
The names should say it all !
Marty.
Marcos - Munky
« Reply #49 on: August 26, 2005, 08:45:12 AM »
Hey Heavner, could you post more pics of your car? Very cool enclosure.
James P
« Reply #50 on: August 26, 2005, 09:15:02 AM »
Quote from: MartyMart
studio .....
Marty.
Marty, you are most definitely a pedal monger!! What a great selection of builds, and all top notch too!
I'm looking to get back into pedal making after being away for a while with some personal problems. Will be nice to get into making some pedals. If I can tear myself away from the cricket!!!!!
James P
If i'm not back in 5 minutes, just wait longer...
nelson
« Reply #51 on: August 26, 2005, 11:10:00 AM »
studio .....
Marty.
cool, an original orange squeezer.
My project site
Winner of Mar 2009 FX-X
mojotron
  • Poster2
  • Total likes: 2
  • Mike, Seattle, Only visiting the 3rd rock, John 14
    • http://www.mojotronics.com
« Reply #52 on: August 26, 2005, 11:29:31 AM »
Quote from: bluesdevil
Damned good job with the junction boxes, Mojotron!!  I've been wanting to try 'em out to save a few bucks here and there... I think those shots really convinced me to go ahead.
Thanks, when I started doing these I initially wanted to spend more on parts (and not on Al enclosures); I want to build at least one of everything.. so I've ended up just putting things in Hammond boxes for customers and using the electrical boxes for my own paint/unibit experiments. But, now I like working with electrical boxes so much more than regular enclosures.
corbs and Paul Marossy in another thread had the idea to also do something like what I did with the steel tops, but put them on a set of rails - so you wouldn't have the restriction of the Junction box under it... So that's the next step for me with this.
mojotron
  • Poster2
  • Total likes: 2
« Reply #53 on: August 26, 2005, 11:38:48 AM »
Quote from: wui223
These are steel junction boxes. The bottom is coated inside and out with truck spray-on bed-liner and the tops are painted with the same stuff everyone uses on normal enclosures.
The bed-liner insulates the inside and protects the outside. The each top is a different experiment using painting ideas/tips I got from this forum. I have kind-of standardized on a couple of practices:
- use good self-etching primer
- use very few coats of paint (1-2)
- use many very light coats of clear coats (3-4)
- cover everything with a really heavy coat of Future floor wax (1-2 coats)
free electron
« Reply #54 on: August 26, 2005, 11:45:16 AM »
hi!
these are the things that keep me busy :) latest builds:
"Buffy" - buffer/splitter/dual looper
SubZero - mosfet based dist
PRL Booster - based on old 70's russian germanium transistor, mid/treble boost, has its own regulated negative power supply onboard.
TS Overdrive, made for one of my friends:
Something to Spice the solo - 3band EQ and volume cut/boost
Inside the one of my custom made preamps/switching units:
Regards!
Peter
mojotron
  • Poster2
  • Total likes: 2
« Reply #55 on: August 26, 2005, 11:45:54 AM »
Quote from: Hal
omg if only I had the budget...lol
mojo doesnt use the white things.  :-D
Well,  :oops: if I screwed up the hole -making it too big - and didn't want to spend the time to drill out another steel top - I then used those huge washers.
A fat washer will cover a multitude of sins  :D
kusi
« Reply #56 on: August 26, 2005, 11:52:02 AM »
hi peter (FE)
wow, nice pedals!
were do you buy the enclouser of the looper BUFFY? i search them a long time ago...
i see, that you make the switches with relays. do you have a "secret", that the relays doesn`t make a "klick"?
thanks,
kusi (happy Tube-tank-user :D )
ps: say a nice greeting to lena :wink:  i bought my TT by her by ebay germany!
excuse my terrible english - i`m swiss ;-)
DiyFreaque
« Reply #57 on: August 26, 2005, 12:04:48 PM »
Here's my Dim C rack mount, shortly before my wife came spinning into the driveway on her way home from work.*
Cheers,
Scott
*Just kidding.
free electron
« Reply #58 on: August 26, 2005, 12:12:19 PM »
hi Kusi!
those boxes like I used for Buffy you can buy at www.elfa.se
Check out the Reichelt also, i've seen a components to build those boxes there (2xDPL + 2xKOH). Not exactly the same, but the idea is similar.
Yeah, the clicks&pops from relays can be PITA.. ;) Most of my switching devices are controlled by Atmel uCs, so i can precisely set the timing of the switching procedure, for example:
All outs Muted
wait some ms
do the switching
wait some ms
all outs Mute off
As muting elements some FETs, or optoFets can be used. I use mostly H11Fx series opto-fets.
I hope You like the TubeTank :) I've got some ideas for new versions of that pedal...
Thanks for the greets for Lena, she will get them fast! :)
Regards!
Peter
« Reply #59 on: August 26, 2005, 12:47:39 PM »
YOUCH...these pics are making me shamed !!!
  MM Has ALOT of boxes already...
  Free Electron...amazing stuff, but I'm not worthy to comment... :oops:
