biggy boy
Finally have my first stompboxes boxed up and painted.
I went with a poster theme.
I used normal paper with a bunch of lacquered coats.
Gus Boost
Big Muff
Back of Big Muff
Fuzz Face Sili
Digi Reverb from GGG
Tremolo
Glen
arma61
Hi there
Housed my wrong pcb of a DriveMaster, (messed with Vref and Gnd!), but it sound good and I like it so I thought I ought give it a house!!  :D
cheers
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
German
You can put inside a good TUBE higain preamp.
cathexis
Here's a lab box I just built, on top of a scope i found cheap. Not a pedal but sure good to have around when building some. XR2206-based frequency generator, pink noise generator and a frequency generator (kit from Nuxie). I just have to rotate that sine/saw switch, then it's done.
LARS
gutsofgold
that looks awesome! any other pictures of the enclosure you used?
aziltz
Quote from: cathexis on June 13, 2009, 03:02:52 PM
LARS
makes the expensive ones in my RESEARCH Lab look like garage sale finds...
The French connection
Quote from: biggy boy on June 13, 2009, 12:10:07 PM
Big Muff
Same inspiration! Great mind think alike! I dig the GGG Reverb, does it sound good?
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
biggy boy
Quote from: The French connection on June 13, 2009, 07:49:54 PM
Big Muff
Dan
Hey cool Dan! yours looks great!
Yes the reverb sounds great, really enjoying it.
It eats batteries thou, I need to get a power supply for it.
knealebrown
Heres my first guitar pedal build, admittedly it has a grounding issue but ill sort it out A.S.A.P. Decided to paint it by hand as im giving it to a friend for his 21st (more personal touch). Thanks for the help guys. Hopefully i shall be posting more in the coming months.
''99 problems but a glitch aint one!''
cathexis
Quote from: gutsofgold on June 13, 2009, 03:50:41 PM
Thank you! I do indeed:
solderman
Quote from: solderman on June 07, 2009, 05:40:56 PM
Here is the Donkey Kong. I gave it its name because it can sound like those old Commodor VIC 64 games and arcade games from the early 80:s. 4 switches and a pot was a menace to wire. Its based on the Slacktave MKII. I'll post more in the 1590A thread, tech info, project files and sound samples etc. as soon as I have had time to record it and compile the info.
//Solderman
Updated with sond samples here
http://www.diystompboxes.com/smfforum/index.php?topic=64752.msg632141#msg632141
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
biggy boy
#9691
Following the poster theme, here's Mark Hammer's Chaos.
This is a great sounding metal pedal.
Really like the way the tone control works.
The finish is polished aluminum.
Link to the schematic
http://hammer.ampage.org/files/Chaos.
Back side
Glen
edd101
Quote from: biggy boy on June 14, 2009, 03:56:42 PM
Back side
Glen
WOW!!! :icon_eek: :icon_eek: :icon_eek: this pedal represents a real Chaos!!! love it!!!
...it is always funny until someone gets hurt!!!
biggy boy
Quote from: edd101 on June 15, 2009, 04:09:51 AM
It's kind of fun searching the internet for these old posters and trying to match them up with a pedal theme.
doc_drop
Hi Guys,
I am posting to show you some of my latest builds. I used Frequency Central's (aka Rick's) overhead transparency film trick to finish these. I am still perfecting it, but it works much better than paint for me. These are built in $4 Radio Shack boxes I scored recently.
So, first up, a couple of views of the family:
Next my version of the Tremulous Lune, and the Clari(not):
Here is one of a Whisker Biscuit and a Prof. Tweed in one box. The guts are ready to be installed. I give each circuit an in and out jack so I can run them independently or one through the other in either direction. The DROP Channel is similar but has a Tonemender and an RMX Distortion:
And lastly some gut porn shots for all you pervs:
Aw - I feel like a proud parent!  :D
doc_drop
As well you should, Rick.
I just posted these on the West coast in California at 10:30AM local time. I am amazed you saw them so fast in the U.K. (I think we have 9 hour time difference, so it must be night there.)
It really is amazing what the internet has done to and for our lives. I doubt I would have built any pedals at all if it weren't for sites like this!
DWBH
solderman
Quote from: doc_drop on June 15, 2009, 02:31:13 PM
Hi
Nice boxes and layouts. reminds me of some props from an old 60:s TV show like "Lost in space" some thing Dr "what ever his name was" could use or some thing "Flash Gordon" wold use ;D
BTW no stomp switches how do you engage them??
www.soldersound.com
doc_drop
Ha ha. I was wondering when somebody would ask. I don't really use these as "stomp" pedals. I am a synth player mainly, so I use them like effect processors, sitting on a table. I just plug them in to the effects loop in my mixer. Or I just plug them through each other when playing at home.
If I were gigging with these or wanted to sell them, I would probably have to give them a stompable bypass switch.
My other, uh, "innovation" is that I use wall warts to power these. I just cut off the regular connector at the end of the cable and solder on a 9v battery cap. Then I put another one on the outside of the box to connect to.
Can you tell I am cheap?...
