OT; leaking caps
Started by Bernardduur, August 25, 2005, 09:01:24 AM
Bernardduur
There is some brown "goo" on the PCB of my amp (bought a 1982 Peavey Mark IV bass amp) and all over some caps; are these caps leaking?
Is that bad for the amp / does it change the sound I should get from the amp? Should I replace them?
And how come some of the goo is on places no cap is in?
Am learning something new every day here
SquareLight | MySpace account
MartyMart
Maybe someone got desperate at a gig and took a "dump" in the amp !!!
( just kidding :wink: )
Could be "old" glue to hold them in place, does it sound "bad" like if they
were blown it wouldn't work .... right ??  !!
Marty.
Bernardduur
It sound fine, but I haven't heard one so I can't compare. On one part of the PCB it is a real mess.
It could be glue though.... it's everywhere
DaveC
Does anyone smoke around your amp? If so it could be tar/resin on the pcb.
Bernardduur
Paul Perry (Frostwave)
Here is a test for the brave:
get a moist cotton bud, run it over the goo, then taste it.
If you CAN taste it, it is probably decayed electrolytic.. or cat piss.
Seriously, if it is lumpy it is probably hot glue.
The Tone God
Check the filter caps particularly around the positive end. Do you see any bulging or similar looking liquid coming out ? Then you may have had a cap burst.
My money is on glue.
Andrew
Ripper
leaky caps usually leave a very light oily sticky mess when they leak, somewhat like if someone spilt an oil.  Lots of the amps used a glue to around the caps.  It is still done today.  If a cap was leaking that bad to make such a noticable mess you would really hear it in the amp, as that cap would have failed completely.  You do need to be careful with leaky caps as some of the old ones do contain pcbs.
Bernardduur
Than I think it is glue...... Everything works normal.
<did not taste it though>
Paul Marossy
Quote<did not taste it though>
I wonder if it tastes like chicken or beef...  :lol:
Penguin
Quote from: Paul Marossy
everything tastes like chicken
we are in the matrix
so maybe they just screwed up what chicken taste like.
"babys taste like chicken. no its true  canibals say people taste just like chicken so there fore babys must taste like chicken..  go to california and put babies on spikes."   Eddie Izzard
In a corner of the churchyard, Where the myrtle boughs entwine, Grow the roses in their poses, Fertilized by Clementine.
niftydog
well, if you're not man enough to taste it, the smell of rotten eggs should give it away too. :wink:
niftydog
Shrimp down the pants!!!
Paul Marossy
This is starting to sound like "Fear Factor"  :lol:
Bernardduur
Brett Clark
DON'T taste it.  If it's oily or "crusty", it may be from the caps. If it's rubbery and tough, it's just hot glue - Peavey used lots of it at that time in an (often vain) attempt to anchor heavier components to the board and take stress off the solder joints. By the way, Peavey generally used very good quality components "back in the day" - cracked solder joints are far and away the most likely cause of any failure on that era of Peavey.
By the way, the built-in effects on 70's-early90's Peaveys are often very cool in an excessive, unsubtle sort of way. Their built in phase-shifter effects and some of the distortion circuits are very unique.
