Easy Chorus & Fuzz??
Started by siaoguitar, August 30, 2005, 01:01:23 AM
siaoguitar
Hi, what's the simplest Fuzz & Chorus pedals to build? any suggestions?
Is it the Zombie Chorus?
Cut the short end of a large perfboard off so that you have a long board, about 10-15 spaces high.
 Build a transistor stage on that board, starting from the right.
 This'll be a booster and will teach you alot/
 Build a second transistor stage to the rightmost open board area, you might want a volume control there. This will be Fuzz.
 Put diodes to ground from the signal path output of the Fuzz Stages for Fuzz Fun including forays into diode choices and voicings.
 What type of transistors would you like to start with, and what type of Fuzz do you want?
 scratch that...build an EZ Drive.
Hal
easyvibe...kinda chorus ?
sounds easy and is great sound, 'easy' for a phaser, phasers arent' easy.
siaoguitar
