Ross Compressor breathing/popping ?
Started by SuperGeo, August 31, 2005, 07:08:28 PM
SuperGeo
Hello
I finished build an Ross Compressor yesterday. It seemed to work very well but when I stopped playing and then hit an string, a sound like a pop appeared.
I've read an topic that said that the trimpot had to be set in the middle, but doing this don't take the pop away.
I was using two 2n3904 and three bc550 so I thought that it could be the problem so I took off those 550 and put three 2n3904 so all transistors was the same model
but when testing again now the pop still remains :(
I'm using an 2k2 trimpot, because there was no 2k trimpot here, can it be the problem? should I just put two 1k resistors in place of it?
Thankss
