SOT Self contained minimalist glitch electronica
Started by Tim Escobedo, September 01, 2005, 01:04:25 AM
Tim Escobedo
http://www.boingboing.net/2005/08/31/music_device_in_a_cd.html
What could that be in there? Though the description is vague, imagine a self-contained, possibly interactive, consumer-oriented music generating device!
toneman
brad
I reckon it must be some kind of ROM.
* battery
* two piezos
* switch
* jack
* volume control?
Interesting idea though!
loscha
which part of sin theta plus index times sin theta times ratio do you need me to clarify to you?
SeanCostello
The title "One Bit Music" should probably be taken literally. The site has a video (of a dance performance), and the soundtrack sounds like it could be performed on a device with stereo 1-bit outputs. All of the sounds are either pulse waves (on/off, with controllable duty cycle), or noise burst, which can be generated as pulse waves with a randomly varying duty cycle. It sounds like there might be some volume variation, which would imply more bit depth than what is needed to produce on/off, but this could be a result of filtering inherent in the system.
Sean Costello
