cd4053 switching touble
Started by Storing!, September 04, 2005, 08:13:26 AM
Storing!
Hi all
I'm doing a project with a EM flanger that's made stereo in stereo out. So to achive something that goin to be more or less true bypassing both signal paths I's using a 4053 switch as described on the handy dandy Roma page
http://members.shaw.ca/roma/switching.html
The problem is that this takes away a lot of top high end, besides that there is a very noticable volume drop. I A/B the switch to a direct connect.
the resistance over the switch is 360 Ohms, so that can't be the problem.
Any help would be appreciated.
Eric
bioroids
Hi!
You should better read http://www.geofex.com/Article_Folders/cd4053/cd4053.htm
I dont know what Roma was thinking, but those 100K resitors are way too low impedance for guitar use. I think you should buffer the signal before going to the switching (always a good idea with electronic bypassing).
Note that this is not true bypass in any sense!
Luck
Miguel
Eramos tan pobres!
