Convert a 100 k Log pot to a 50 K log pot?
Started by mathflan, September 09, 2005, 08:36:37 AM
mathflan
Hi,
I'd like to know if it's really possible to convert a 100 K log pot to a 50 k log pot.
I know that you can convert linear pot to a log or linear pot by the Help of the site " Electronics Math Helper"  http://www.diystompboxes.com/analogalchemy/emh/emh.html
But can I convert LOG pot to anything else.
http://sounddiy.free.fr
Bernardduur
Am learning something new every day here
SquareLight | MySpace account
bioroids
You can put a 100K resistor in parallel with the pot.
Luck
Miguel
Eramos tan pobres!
MartyMart
Just put a 100k resistor across lugs 1 & 3 .... DONE !!
Same for a 1M to a 500k just use another 1M resistor .. etc etc :D
Marty.
mathflan
dr
....better make that a log resistor!.......(sorry- had to!)
jimbob
Lets sat youy wanted a 100k and had a 500k? what kind of resisrors would you use for that?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
bioroids
You use the formula for parallel resistors. Say the por is R1 and you add a resistor in parallel R2. Then the total resistance Rt is:
Rt = 1/(1/R1 + 1/R2)
When using pots, the taper can vary when adding resistors in parallel to them.
You should read the Secret life of pots at GEO http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
Luck!
Miguel
Eramos tan pobres!
mathflan
jimbob :
I want to convert a 100 k log to a 50 k log pot using metal resistor ( 0.25w 1%)
SO What I have to do? pu a 100 k resistor across lug 1 and lug 3 or put 2 resistor in parallel??
Paul Marossy
trjones1
What is the taper % on the taper pots calculator?  Is 90% a regular audio taper and 10% reverse audio?
mathflan
I don't understand the tape % too.
Thanks Paul, I love what you do, your site is great.
Paul Marossy
Quote from: mathflanI don't understand the tape % too.
Glad you like it.  8)
jimbob
Lets sat you wanted a 100k and had a 500k? what kind of resistors would you use for that?
put a 250k resistor between  lugs 1 and 3?
bioroids
No, a 250k resistor will get you a final R of 166K. You put a 125K (120K is the closest standard value) and that gets you down to 100K.
It's just a matter of parallel resistors, using the formula I typed in an earlier post.
Luck!
Miguel
Eramos tan pobres!
audioguy
How about 1m linear to 500k linear? Looking at this it LOOKS like I would put a 500k resistor on lug 1 going to 2 and another on lug 3 also going to 2- is that correct?
AG
MartyMart
Yes that works !
How's this got to several pages BTW ??  :?
Marty.
