Mongoose Fuzz; any schems?
Started by Bernardduur, September 17, 2005, 04:23:01 PM
Bernardduur
Hi all.
I've got a burnt down Mongoose fuzz for free; one problem: it is completely burnt down (black, black, black). There are some good resistors and caps, but most is gone.
Anyone has some kind of schematic so I can try and fix it........ I want to keep it in original state........
Am learning something new every day here
SquareLight | MySpace account
cd
LOL unlucky for you, the search is not working.  That pedal was dissected like a frog in biology class.
Anyway, it's your lucky day:
In the future, when it's back up, the search function will be your best friend.
Bernardduur
Thanks man! You saved me!
And yes, I've tried the search. Lukily the site is up again; did not know what to do without this..........
addiction?
Bernardduur
Anyone tried the schem? I only get this kind of sputter fuzz that does not react to the fuzz knob
And yes, I checked it all more than once.
Steben
Quote from: BernardduurAnyone tried the schem? I only get this kind of sputter fuzz that does not react to the fuzz knob
Collector on Q1 should be very close to 4,5V I guess to prevent gating on the IC. I guess you DID connect pins 7 and 4 on the Opamp?
Bernardduur
Yes, I connected pins 4 and 7 (and the right way BTW). Voltage on the collector of Q1 is far from 4.5V (0.24V). Voltage between R4 and R5 = 4.5V
Steben
Quote from: BernardduurYes, I connected pins 4 and 7 (and the right way BTW). Voltage on the collector of Q1 is far from 4.5V (0.24V). Voltage between R4 and R5 = 4.5V
Aha!!! Try to connect that in-between point to the + input and C4 then. ;-)
It should work.
Bernardduur
OK. Now I am getting some Fuzz; only when the volume knob is fully open and the fuzz knob is at 9/10th of it's turn.
Steben
Quote from: BernardduurOK. Now I am getting some Fuzz; only when the volume knob is fully open and the fuzz knob is at 9/10th of it's turn.
Actually I checked all available schematic stuff and the input of the Opamp should be indeed connected to the collector... :roll:
It should make for more gain off course, but the biasing voltage of the opamp is odd. 0.24V is way too low.
Doug_H
There is a mistake in the schematic posted earlier in this thread. The 2M2 resistor should be connected between the base and collector of Q1. It provides negative feedback for the stage. This will put the collector voltage at around 3.5v, perfectly acceptable (according to my sim). According to the sim, this sucker should really blast...
Doug
Bernardduur
That was it!!! Thanks all.
I made a new schematic; it can be found here: http://www.student.kun.nl/r.kerkhof/Mongoose.jpg
Steben
Quote from: Doug_H on September 20, 2005, 01:13:37 PM
Doug
This suggests Marty's layout is incorrect then?
Bernardduur
It is 99% correct. Check my new schem above
puretube
Bernardduur
#14
Me? I just changed the schem
puretube
Never trust a schematic on the web - NEVER!
MartyMart
That's interesting as it was drawn out from original photo's of mine !!
And the version that I built is working a treat !! ??
I will however "dive in" and make that 2M2 a feedback resistor across
Q1, I'll let you'all know what happens ..... !
Marty.
puretube
I do trust photos, though (when un-edited)...
Doug_H
Try it and see, Marty. I haven't actually tried it. It just didn't look right and didn't work without the mod in the circuit sim.
Doug
Bernardduur
"and my clone just gave me hard times getting some tones out of it"
