Is there a common reason...??
Started by Mike Nichting, September 06, 2003, 09:10:17 PM
Mike Nichting
I am building 3 different pedals at the same time, well not exactly at the same time, but a little here and there one after the other.
I am having problems with one of them.
I get a bypassed signal but no effect. Is there a common reason that this happens??  I am not in the frame of mind to continue to take my meter to it anymore and I have had this problem before but it was a defect in the schematic. I know this schematic works because I've built it before.
Any help for a tired almost cross eyed solder soldier??
thanks
Mike
"It's not pollution thats hurting the earth, it's the impurities in the water and air that are doing it".
Quoted from a Vice President Al Gore speech
Paul Marossy
When that happens to me, it's usually a problem with the power supply or I wired something wrong, accidently ommited something, or made a wrong connection somewhere.
aron
Yep, power - like forgetting to ground an op amp (my favorite) or bad solder joint at a coupling capacitor.
etc... etc...
Jered
I would also add, build one effect at a time so you don't make the same mistake on the others you are building.  Jered
Mike Nichting
yeah, it would be best if I could just work on one at a time wouldn't it :-)
  I will check the power and all~!!
Mike
I've gone through debugging processes with projects before that were completely unnecessary> the problems were directly related to NOT labeling the input and output jacks [dohh] might seems silly, but 'ya' gotta check the 'small' stuff too sometimes.
