EH Hoax
Started by moosapotamus, September 23, 2005, 11:54:53 PM
StephenGiles
No, it includes a special circuit which induces hiss if there's an R in the month! ::) ::) ::)
Stephen
notchboy
Actually, there once was a flanger with a built-in optional pink noise generator:
http://aulos.calarts.edu/pipermail/music-dsp/1997-December/019897.html
There you go - the rack version of the Flanger Hoax could be called the Vacuum Cleaner of the Gods...
puretube
Quote from: notchboy on October 10, 2005, 02:06:38 PM
puretube, I hope you don't me asking, but what is responsible for the hiss coming from the Flanger Hoax?...
did you hear hiss, or did you read hiss ?
notchboy
I heard the hiss myself.  It swells in and out with the sweeping of the delay, or if you tweak the delay by hand, it gets worse as the delay time gets shorter.  As you adjust the blend towards dry, the hiss goes away, so it's only in the wet signal.
It's an incredible box, but the hiss is a big problem IMHO.
puretube
RDV
Hiss is out of my range of hearing. I only hear the ringing. The constant ringing. Somebody please make it stop.
RDV
puretube
