Super Easy More Depth mod for LED/LDR phasers ?
Started by petemoore, September 29, 2005, 10:34:36 AM
  I'm convinced, but you tell me....
  I tried this on the EZ Vibe, and was presented with a much more lush sounding wobble, excellent for those wobbly tones, this also seemed to me to markedly increase the depth of it too.
  It is so easy [if you haven't light shielded your light section yet]...
  I found that the EZ Vibe has more than enough brightness [when the depth control is about 7-8, at least thats about the highest setting where I was liking it...so decided I had 'some extra light' to play around with.
  I decided that the LED/LDR 'accurate alignment' trick is probably not really necessary and then soon gravitated with the idea to limit light to some of the LDRs...
  I stuck two layers of typing paper between 2 of the four LED/LDR sets...then I played BOS [trower] and other heavily phased phrases for a...couple hours, marvelling at what I percieved as the deeper lush phaser tones.
  I was amazed...and would like to know what you think...
