Integrated Circuit
Started by Screaming Solo, November 03, 2005, 04:01:46 PM
Screaming Solo
hey im really close to starting my first project yay
but i need to know if my local electronice store (radioshack) would have the IC i need
i heard it can be hard to find the rigt IC you need the one i need is a 4558 for the Ibanez Tubescreamer should i be able to find this there? if not where could i buy one
niftydog
If you're not worried about the "mojo factor" of the original JRC4558D, then you should find it relatively easy to find another manufacturers 4558 op amp at a half decent electronics store.
niftydog
Shrimp down the pants!!!
Ge_Whiz
Use a socket for the op-amp IC, then you can use almost any dual op-amp to get the circuit running, then update the 'mojo' at a later date.
Screaming Solo
alright thanks alot
will using a different op amp degrade the quality noticibly?
niftydog
Using a TA4558 as opposed to a JRC4558 for instance will not produce a noticeable difference IMO.
niftydog
birt
just try a couple. you might like (for example) a tlo72 better than a 4558
http://www.last.fm/user/birt/
Screaming Solo
hey i think i'm actually just gonna buy off of small bear electronics it seems like they have everything i need to build this
this may sound dumb but the enclosures he sells for $13.50 will work for housing my project right?
http://www.smallbearelec.com/Detail.bok?no=48
also looking at the schematic i'm using (the one from tonepad for the ts808 tubescreamer) i dont see a switch for bypass how would i put this in? do they have it at small bear
http://www.tonepad.com/project.asp?id=1
thanks alot for the help
beens
That enclosure would work very good for this project. And smallbear also has the switches you need, the easiest would be to use a 3PDT switch (Aron who runs this forum also has them for sale). As for wiring them up there is a own project at Tonepad found here: http://www.tonepad.com/getFileInfo.asp?id=76 which should explain it for you. Scroll down and you will find the wiring shematic for the 3PDT switch.
Good luck with your build!
Bjorn
Screaming Solo
hey thanks alot  ;D cant wait to get started now that i know what im doing
Steben
These all sounded the same:
KA4558
KIA4558
RC4558
JRC4558
