Electronic switching.
Started by jrc4558, November 29, 2005, 02:02:26 PM
jrc4558
Good day!
I recently decided to rebuild my peadalboard and want to incorporate electronic switching on several pedals.
I like the DOD/Tech21 hex inverter drivig FETs switching, but have never seen a project for a switch like that. I would perf board it, but hesitate, since the chips are digital and i will need several identical copies.
Does there exist a layout for good dependable switching circuit that would allow bot LED and effect switching?
jrc4558
Would CD4016 be any good here?
Roobin
My guess is that you could use any Boss schematic for the switch section (the two trannies). This uses to npns/pnps (cant remember) and a switch. Also try the Tube Screamer, which has basically the same idea. For info on how it works go to the brilliant GEO page and "Technology of..." link in the top left.
I think this is right - any other ideas?
jrc4558
Any ideas on DOD/Tech 21 switching?
Xlrator
I have some 4016s sitting on the desk that I want to try out. Please post your results.
Listen to cKy!
Steben
4016 works fine with SPDT switches. = Electronic relays. When you use it in a combination with a 4013 flip-flop you only need a cheapo SPST switch.
wcampagner
Hello Constantin,
Here is the Tech21 switching that i took from my original GT-2... the only difference is the FET... Tech21 uses a SMD FET... i think it is PN4393... something like that... but i use the 2Sk30A (the ones used in most of the Boss and Ibanez pedals)... forget about the 2N3819 in the picture... i was testing them, but the 2SK30A are much better...
I hope it helps.
Thanks,
Wagner.
Quote from: Constantin Necrasov on November 30, 2005, 01:40:19 AM
Thanks,
Wagner.
bioroids
Check out the Electronic Switch article at GEO http://www.geofex.com/Article_Folders/cd4053/cd4053.htm
CD4016 and CD4066 can also work. I think someone (Gringo?) had a PCB layout for this switch, or a similar one.
Also you should read thw Wicked Switches article at Tonegod's site. Can't find the link at the moment.
I think an explanation of DOD style switch was at Mark Hammer's site ( http://hammer.ampage.com but seems to be down at the moment)
PN4393 are good Fets for switching too, and you can slow down the control voltage to minimize popping (you cant do that on a CD4053)
Luck!
Miguel
Eramos tan pobres!
Quote from: bioroids on November 30, 2005, 06:50:49 AM
...likely because the suffix is .org not .com  No problem, easy mistake to make.  Here is the doc in question:  http://ampage.org/hammer/files/dodswitch.gif
GFR
Mark, I can't open your site for a long time.
I tried hammer.ampage.org and ampage.org/hammer, both at work and at home. I tried IE, Firefox and Opera.
IE:
QuoteA URL solicitada não pode ser recuperada
Na tentativa de recuperar a URL: http://ampage.org/hammer/files/dodswitch.gif
O seguinte erro foi encontrado:
Falha na conexão
O sistema retornou: (110) Connection timed out
O host remoto (servidor) ou a rede pode estar indisponível. Por favor tente novamente.
Server not found
Firefox can't find the server at www.ampage.org.
    *   Check the address for typing errors such as
          ww.example.com instead of
          www.example.com
    *   If you are unable to load any pages, check your computer's network
          connection.
    *   If your computer or network is protected by a firewall or proxy, make sure
          that Firefox is permitted to access the Web.
QuoteCould not locate remote server
You tried to access the address http://ampage.org/hammer/files/dodswitch.gif, which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any Internet security software is correct and does not interfere with ordinary Web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the Internet. Reload the page.
Need help?
Open the Opera Help.
Go to Opera's on-line support desk.
The only way I can access your page is through www.archive.org but it's not 100% of course :(
bioroids
Quote from: Mark Hammer on November 30, 2005, 10:28:09 AM
Oops! :icon_redface:
I can access it fine using Firefox and Win2003, by the way.
Luck
Miguel
Eramos tan pobres!
Roobin
no one ever
personally, i would like a layout of an spst switch-based dual-logic chip electronic dpdt.
(chk chk chk)
jrc4558
That would actually be a good idea. I am currently attempting to do a compact layout for Tech21 switch, but being an amateur with no training in pcb layouts makes things way too slow for someone who steals 30 minutes every four days from school, work and music. Perhaps someone could bo it better/faster. :) But I wont give up. Just dont expect it all too soon. Its slow process in my dimension. :)
GFR
