Tech 21 XXL build question ...
Started by MartyMart, December 07, 2005, 08:00:12 AM
MartyMart
http://www.diystompboxes.com/smfforum/index.php?topic=29094.0
Here's J Luja's nice schematic.
Can I just ignore all the switching circuit and use a single TL072, with perhaps
just a vol recovery stage after the volume pot ?
So I keep warp/gain/tone/vol pots and circuitry ....
Thanks,
MM.
stm
Quote from: MartyMart on December 07, 2005, 08:00:12 AM
Thanks,
MM.
Certainly! Really simple and compact circuit.
Take notice the two opamps are of different type TL072 and TLC2262, and we know from the GT-2 experience that there is a sonic difference in the way they clip. You will need to try with both types and see which one you like best, or use a TL071 for the first one, and then a TLC2262 and use the second half of it for the output buffer stage (recommended).
Good luck!
MartyMart
Thanks stm, it was looking quite "straight forward" ..... and that's when I start to panic !!
I've got some 2262's coming ..... but have decided to use a single ic and a simple volrec
with an MPSA18  !
Do you think "after vol pot" or shift it to before vol pot ??
So,  tone circuit -> recovery -> 100k pot ( without the "VB" connection )
MM
stm
The original circuit has a buffer stage (unity gain), not a gain recovery stage. As such, I would simple use the transistor as an emitter follower (let's say with a 4k7 to 10k emitter resistor) after at the volume pot wiper.
H S
Isn't the Tech 21 XXL in the "No Clone Zone"?  It's in current production, it's only about 10 years old, and it's not a clone of anything else.
