Clocknoise..
Started by Storing!, December 08, 2005, 12:01:25 PM
Storing!
Can't seem to get rid of clocknoise in a very tight build Electric Mistress. (It sounds gorgious though)
The problem is not a slicht ticking in the engaged mode, but the bleeding of clock ticking in the bypassed mode.
I'm useing the true bypass milennium switch method.
Is it possible it goed through the grounding?
This is driving me nuts. Already shielded the in and output wires with very little succes.
Any ideas?
Eric
markphaser
Try Filtering or De-coupling the Ticking sound
Run the clock lines on a seperate power supply and seperate the grounds and hots for the clocks chips
StephenGiles
By tight build do you mean on a board so small that it will fit into one of those compulsively (of late) small boxes? Then if the answer is yes, I am not surprised.
Stephen
