Dirty Sanchez Vero layout
Started by Toney, December 09, 2005, 05:29:44 AM
Toney
 Just a quicky, with thanks to Dragonfly.
schem here:
http://aronnelson.com/gallery/Dragonfly-FX-Schematics-%21/DIRTY_SANCHEZ_SCHEMATIC
Crackle, splat, ronk.......Eeees feeelthy.
Toney.
Connoisseur of Distortion
no slowing you down, huh?   ;)
vero layouts are very nice. my least favorite part is cutting traces, but even that's not too bad...
MartyMart
Very cool !
Re cutting traces :
I have a screw driver body/handle with a grub screw for fitting heads,
a 5mm drill bit fits in and can then be used with some comfort... perhaps
this idea helps ?
MM
MartyMart
Toney, i like the added 1N4001 protection diode, if you made it
one hole wider, you could squeeze in a small 47/100uf power filter cap too !
I use them all the time ....
:D
Toney
TheBigMan
Wow Toney, you're cranking them out.  Another very nice looking layout.  :)
I use one of those trace cutter thingies which is just a drill bit in a handle.  Got it for £2 or so from Rapid, Maplin want £7.50 for the same thing!  Sometimes if I'm short of space I'll just slice the trace with a scalpel rather than taking up a whole pad though.
Dragonfly
nice looking layout !
couple of things you might address....
1) you might wish to label the C-B-E  transistor locations on the sockets.
2) my last name is "Carrell", not "Carrel"  ;)
3) for those wishing for less "nastiness", playing with the values of the 10k resistors on Q2/Q3 will help bring them into proper bias....me, i like the nastiness  :icon_twisted:
rock on !
andy
wampcat1
Quote from: Dragonfly on December 09, 2005, 02:12:55 PM
rock on !
andy
DOH!! I thought it was Carroll...I must change that in my book!!  :icon_redface: :icon_redface: :icon_redface: :icon_redface:
jmusser
Hey Dragonfly, didn't you mention something one time about having a sustain feature on that pedal, so that you could switch in and out from the gated tone, to a smoother tone for leads? It may have been no more than just routing it through a higher resistance pot, and adding another stomp switch, but I can't remember.
Homer: "Mr. Burns, you're the richest man I know"            Mr. Burns: Yes Homer It's true... but I'd give it all up today, for a little more".
bluesdevil
As Discussed in a previous post, put a Darlington in the Q1 spot (MPSA13 or MPSA18?) and it's a real monster!!
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
bluesdevil
Also change the 10k that's on the collector of Q3 to 47k... thickens it up in tone and less gating. I ended up putting a switch between the two. These mods really bring out the killer thats lurking in this pedal!!!!
Dragonfly
Quote from: jmusser on December 09, 2005, 02:45:53 PM
Q2/Q3 collector values can be made switchable....  or you can just use a pot/trimmer and adjust to taste !
Dragonfly
Quote from: wampcat1 on December 09, 2005, 02:16:37 PM
i exist simply to confuse people !
Dragonfly
Quote from: bluesdevil on December 09, 2005, 03:27:43 PM
mpsa13 works well...
also...this has a LOUD volume boost, so keep it turned down when you power up your rig !
Toney
#14
Gee, posting when tired never the best idea. :icon_rolleyes:
I'll fix that now , mate. :D
Toney
#15
 Let me add a vote for an mpsa13 in Q1.
Becomes mental boost/sustain machine.
Fun,fun.
Ken
G'day all,
re: cutting vero board traces try using a small drill bit works perfectly for me.
:icon_biggrin:
Cheers Ken.
