the ultimate two germ.transistor FF ? What is it
Started by donald stringer, December 11, 2005, 04:57:48 PM
donald stringer
I have two oc128 that I have been saving,[ left over from an order from jack] Without wading through tons of fuzz face schematics which one would be the best build, the most bells and whistles available from two transistors. I need something tried and proven. Thanks a lot!
troublerat
birt
fuzzface with a switch for an extra gainstage (use a silicon for this stage) to get a tonebender. Use a switch for different inputcaps for different sounds. do the temp stability mod. reverse polarity protection too.
you can also add a bias pot on the outside of your pedal
http://www.last.fm/user/birt/
